Blow Log Specs?
- Wildwood
- Name: Jan Johnson
Blow Log Specs?
Please describe the ideal size blow log. My son & I keep finding hollow logs . . .
I can use some hints and tips on what to bother with getting back home for fun use later.
Thanks.
Jan
Thanks.
Jan
Jan Johnson
Re: Blow Log Specs?
We've lit 'em from 3' to 12' long and 10" diameter to probably more than 3 feet. If you're looking for optimal, maybe 5-6' long and 1.5 ft diam is a large but manageable size. The main thing is that it's hollow all the way thru (has to work as a chimney), that it's at least a bit flammable, and that air can get sucked in the bottom to feed the "blow". Lots of design ideas out there, but maybe the safest I've seen (and blow logs by their nature are not what most people would describe as a safe activity so err on the side of caution, especially with kids around) is to use bricks with spaces in between them to rest the log vertically on to provide a stable base and good ventilation. Then guy wire the log three ways so it can't fall over prematurely. Then build a fire nearby and get a bunch of hot coals, which you can transfer by shovel to the space under and around the log, leaving enough room for air to get sucked in the base. Takes a bit for the heat to build and get the engine going, but as the inside of the log catches fire, it'll almost always put on a good show.
BTW, I do not recommend building a fire first and then moving the log into the fire. Billy W. has scars on his hands to prove that's not the smartest way to light a blow log...
- Fish
- Fish
- Shark Attack
Re: Blow Log Specs?
There is one in a pile on the south side of Davids Small Engine in Mayflower
Wes
Re: Blow Log Specs?
i've read all that twice and still cant findFish wrote:We've lit 'em from 3' to 12' long and 10" diameter to probably more than 3 feet. If you're looking for optimal, maybe 5-6' long and 1.5 ft diam is a large but manageable size. The main thing is that it's hollow all the way thru (has to work as a chimney), that it's at least a bit flammable, and that air can get sucked in the bottom to feed the "blow". Lots of design ideas out there, but maybe the safest I've seen (and blow logs by their nature are not what most people would describe as a safe activity so err on the side of caution, especially with kids around) is to use bricks with spaces in between them to rest the log vertically on to provide a stable base and good ventilation. Then guy wire the log three ways so it can't fall over prematurely. Then build a fire nearby and get a bunch of hot coals, which you can transfer by shovel to the space under and around the log, leaving enough room for air to get sucked in the base. Takes a bit for the heat to build and get the engine going, but as the inside of the log catches fire, it'll almost always put on a good show.
- Fish
- Wildwood
- Name: Jan Johnson
Re: Blow Log Specs?
Prophet, I think the
was in the planning stages, when explosions came to mind . . .
Jan
Jan
Jan Johnson
nathan richard
- Name: nathan
Re: Blow Log Specs?
we're gonna burn our first big blow log tomorrow night. we practiced with a couple little ones last weekend. i'm pretty excited. any other tips would be appreciated.
Re: Blow Log Specs?
no tips but enjoyment unless you add explosives, but thats for lower class fire watchers
and they get what they deserve.
if you're gonna be dumb ya gotta be tough
nathan richard
- Name: nathan
Re: Blow Log Specs?
There will be a few low class fire watchers out there tomorrow night. anyone else that wants to come out (low or high class) is welcome. we'll be out HWY 412 between tontitown and siloam springs.
